Mounting sub box
you could buy metal "L" brackets with holes for screws, then just use those to screw the box to the trunk floor.
i was hoping that there would be someone with a different way to mount it than drilling in to the car. i noticed in the back today there is a screw on both the left and right sides holding rear panels in and maybe i can find some brackets that will reach them because they are about 6 inches away from my box
well, you could always try attatching a net from one of those screws to the other right infront of your box and see if that holds it in place.
