DNA_Cyan
- 42
- Oct 10, 2002
Hi guys,
Would side trimmings from a 1991 Mitsu Eclipse GST fit a 1990 Eagle Talon TSi AWD??
I mean everything, including the door side trim that's located 1/2way along the door.
For a 90 Talon, on each side of the car, there should be a total of 5 pieces of trims (if I am not wrong).
1 huge piece right at the bottom that extends from the front wheel well to the rear wheel well. A second larger piece located at the bottom of the door to complement the 1st huge piece. These 2 pcs will form the side-skirt.
The other 3 pieces are the side trims located 1/2way up the car. 1 piece behind the front wheel well, a longer one along the door, and a 3rd one in front of the rear wheel well.
The reason I am asking, is because, I am missing 2 pcs of these 5 trims on my driver's side. I'm missing both pieces located on the door itself.
I found someone selling this trims, but its from a 91 GST. Are they the same trims? or different ones??
Thanx in advance.
Thanx in advance.
