eclipse500
- Jul 26, 2008
Radisson,
Wisconsin
I have a 95 rs that I have been converting the doors to power doors. I have doors that were off of a car with power options, everything is in the doors. They plugged right into the car, I checked the two fuses between the kick panel and engine bay fuse box. Both the 10 amp power door lock fuse and the 30 amp power door fuse were in place. I turned the car on and Nothing happened!! It appears that I have power to the door switch's harness. So I was thinking the master switch on the drivers side was bad, causing nothing to work. But if anyone knows of any other relays or fuses that need to be checked please help. AND PLEASE BE SPECIFIC!! There are a lot of relays in a car, so please don't tell me to look for the black relay with wires plugged into it under the dash!! Thanks for your help and patience reading this!
The IDIOT that sold me the doors just completely screwed the wiring in the doors, the power lock actuators were replaced with aftermarket ones that were removed prior to my receiving the doors. But the window wires were cut and wired to absolutely nowhere! I had to remove like eight layers of dynamat (well not eight, but it was alot!) And thats when I put my multimeter on the window motor to find out nothing was happening there either! So I found the wires and wired them back together, and voila! Power windows!! What an IDIOT
