Projector Bulb Help
zwickyj
205
Dec 11, 2003
Oshkosh, Wisconsin
If have h1 and h3 bulbs and when I removed the headlight I took out the two clips that were somehow together holding the bulb in. Does anyone have a picture on how this goes back together.
It should be really easy for you to see how that works. You pull the clip down over the new bulb, and there is a little notch that will hold that clip in place tightly over the bulb.
If you are seriously having problems with it, take your headlight to a parts store and just ask if they will help you put it back together. 90% of people out there are nice enough they will help you with that :)
I can kind of see how it would go back, but there is two clips that when I removed them were functioning as one.
