SpYYderT
- 79
- Oct 18, 2005
Utica,
New York
-Car is 96 Eclipse Spyder GS-T, fenders will be rolled.
-Suspension will be K-sport full coilover, lowered 1-2".
-Wheel is ADR M-Classic, 20" x 8.5", offset is +40 or +35 (they come in both offsets).
-Tires will be 225 / 30 / 20 (diameter 25.4") or 225 / 35 / 20 (diameter 26.2").
I searched and have not seen anyone using 20" wheels in this width, i also have seen someone locally use 19" x 8.5" with +38 offset, i would assume with shorter sidewall tires a +40 may work, just want to verify. Thanks.
I simply would like to know, if they will fit.
nice wheels... are you also +40 offset? and what steering wheel are you using, with the tan rim?
