meef
- 534
- Oct 6, 2002
ive got a 98 ESi...was wondering how everyone ran their wires from the trunk to the battery? i mean thru the car some way or another, but how did yall do it? or have it done?
). so basically start from the battery and then thru the firewall and to ur amp ( of course hiding the wires as mentioned above thru wiring channels on the driver and passenger sidesYou may have shielded RCA cables, which are about twice the price of basic RCA cables. The reason they recomend running them seperate is that the RCA cables are sending iformation to your amp at around 5 watts, and everybody knows that the longer the cable, the more wattage you lose, so any high power lines running along side of it could disrupt the signal, or you may just get a whinning noise at low volume. Usually it can be heard if your stereo is on, but the volume is all the way down, then rev your motor a couple of times, if you can hear the motor reving through the speakers or a whinning noise that changes with the rev of your motor, you have interference. That's why the came out with RCA's for car stereo's, cause high power speaker lines directly connected to the amp almost always give you that problem.Originally posted by greyforestgst
weird, i have my rcas and power wire running right next to each other down the wire tray under the door and i dont have any problem...
oh, and the steering column boot is an extremely easy place to run your wires from the cabin to the engine bay.
I really pondered responding to this but I couldn't let it go.Originally posted by ENEVEL RACER
The reason they recomend running them seperate is that the RCA cables are sending iformation to your amp at around 5 watts, and everybody knows that the longer the cable, the more wattage you lose, so any high power lines running along side of it could disrupt the signal, or you may just get a whinning noise at low volume. ... That's why the came out with RCA's for car stereo's, cause high power speaker lines directly connected to the amp almost always give you that problem.
Sorry, I didn't mean 5 watt, I meant 5 Volt. I'm a CAD drafter for a state public power facility, and sometimes type faster than I can think, your are right, it's Volts not watts. But the matter of fact is that a low voltage like that can be diminshed on longer cables since they don't use much wire to support the current. That's why monster cable came out with thicker shielded RCA's. Frankly, I've never had a problem running unshielded RCA's, I just keep them away from power sources, and never get a whine or hum. But thanks for the info.Originally posted by steve
RCA style signal cables have been around for decades. When car audio started they used the same interconnect stardard as used in home audio for years and that turned out to be both useful and unfortunate. The standard was 1v p-p into 10k impedance unbalanced (signal referenced to ground). So an amp would produce it's full rated output with an input of 1v. This works just fine at home but in a car there are lots of noise sources and the unbalanced signal cables are more likely to pick up that noise than say balanced cables. In a given environment the signal level created by noise is constant. With a 1v p-p input a few milivolts of noise is very audible. One way to solve the problem is improved shielding on the interconnects, another is to increase the level of the drive (input to the amp). When you go from a 1v p-p to a 5v p-p the the relative noise level drops 5x. It's still the same noise imposed on the cables but it's a smaller percentage of the input signal so the noise margin inproves.
That said the problem I had with your post was that there is nothing close to 5W used in the interconnects in a normal system. Power = Volts^2 / Ohms. Ignoring conversions to RMS, 1v^2 / 10000 = .0001W or 5v^2 / 10000 = .0025W. At these power levels and a 10k input impedance the resistance of the interconnect isn't a real factor. The issue with longer cables is the longer the cable the more likely it is to pick up noise. Since all wires carrying current create a electric field directly related to the current and wires in a changing electric field will induce a voltage in that wire, putting your interconnect near the speaker wires or power cables can create noise on your input. That noise is always there but as you turn the volume up it's a smaller part of the whole signal and less audible and now we are back to rasing the input voltage lowers the noise levels due to less gain at the amp.
Steve
