What Lip? What Sides and What Rear?
Yeah, the lip looks good but I would just stick with the 2gb sides and rear. That rear "add on" looks ok but the sides are hideous.
I like those sides better than mine. :p I'm stuck with freakin blitz skirts till I can pull em off (molded into the body) and re-spray the pulled areas.
Your going to need a front and rear camber kit and an alignment if you plan on putting 20's on. Has anyone ever put 20's on an eclipse?
Your kidding me right? Tons of people have 19-20" Wheels, it looks normal. Look at that picture I posted above, that Talon has 19's. Rubberburner has 20's, My friend with an RS has 20's. And For stock height you do not need a camber adjustment on the front and rear... but an alignment is normal for any thing you do! I know all about the Eclipse suspension. I'm a performance guy, not a looks guy which is why I was asking about the lip. I'm not used to this body kit kinda stuff.
Rubber burners car without camber adjustments, lowered an inch I belive with 20" Wheels.
