best way to clean white rims??
Snoop-GST
267
Mar 8, 2002
I always have a hard time cleaning of the oil that gets in the rims is there any kind of spray that will make the job easier?
the oil problem got fixed it was coming from some O rings from the block. so is wd40 safe to use on rims?
i think wd40 smells good!! i think its safe to use but will atract dust like they said and then youd have to clean em again
i use some stuff from eagle one. you spray it on , it foams up and then you rinse. it works wonders. i have yet to find anything better, unless you get down with soap and a tooth brush.
I have a good coat of wax on my wheels, everywhere, that will help you clean them. And yes I also get down with soap and a toothbrush. I'm a perfectionist so I guess I won't be much help in a "I need to rush to clean my isht question."
Tom
