Pimp my ride key fob and mini monitor help me find please!!!!
Eclipse45150
103
2
Oct 1, 2004
Milford, Ohio
Ok, and of you who saw the pimp my ride with the cougar know about the center console the fabbed, I called them and asked what the switch in the dash was to open it and they said a kill switch which I know wasnt right cause those were in the center, I need to try and figure out where to find the switch they called a key fob, it was the one in the dash that you stick a key in to open the center console. I need to find out for a mod Im gonna do.
Second, I have some ideas of monitor placement and computer, anyone know of a place to get a 2.5" monitor or around that size and a touch pad mouse for a good price? (tryin to stick away from ebay for these unless I get some good feedback about them)
Please let me know, any information is appreciated!
for a computer anda 2.5" monitor your going to run into A LOT of problems.
There are some very nice 7" VGA touch screen monitors that are around 500 dollars or so.
The beifit to using a VGA monitor for a ocmputer is
1)The quality and resolution
2)You can have touch screen
If ou were to get a regular screen and hook up the computer to it you would gert reall bad quality, and no touch screen.
the 7" screen is actually a tiny bit bigger then the double din slots our cars some with. Got o a junkyard and pick up the plastic trim and buy a case for a screen from www.mp3car.com and mold your self a nice oem looking screen.
I have my molded screen trim done for the center console covered in carbon fiber (very poor job, but i am going to redo it all)
I dont have the actually screen though ( I bought just the plastic case for the screen.. so i dont wreck a 500 dolalr monitor :p)
Any wyas go to mp3car.com for more info on stuff :)
A fob is part of the ignition-hammering weight you use to beat the crap out of the start switch, which also swings around to dent and scratch any surrounding trim while making a dreadful jingling sound, such as the (unused) attached.
See if you can find a screencap of the switch you're looking for. Check sites like JC Whitney and Autoloc for custom switches.
Ill start checking there for the switch, I wish I could explain it better, as for the monitors I am getting a 7 for the airbag, a touch pad mouse for the console and I want to get a mini monitor for the steering wheel, I know the resolution is going to be crappy but its just for looks and points at shows.
