Radiator Cooling Panel
tyger1
268
2
Dec 10, 2005
Clovis, New Mexico
I am looking for an aftermarket radiator cooling panel. I tried searching but came up with nothing. Does anyone know where i may find one. I am looking for a polished panel to dress up my engine bay. thanks
So i guess i'll just have to make one.
well i decided to just polish my cooling panel for now. here is a pic
Just curious but . It looks like you are running a bov in vented mode and I see the stock airmass but it looks like a gm maf up closer to the throttly body elbow ??
yeah I do got my BOV vented, and yes i do have a GM MAF and still have my stock MAF on, the reason is the Injen intake, I want to take the Stock MAF off but the injen intake pipe is oval and when i try and put the filter directly on it the hose clamp comes off. am I missing something? that is where i am unsure of. any suggestions.
The Injen air intake is designed to be used with the stock MAS. Seeing you have a GM conversion, you're best bet is to look into dejontool's (dejontool.com) gm mas/vpc intake pipe.
okay so i finally did my BOV recirculation mod, here is a pic, it is alot quieter but I can still here it go off, not too bad, Hopefully my MPG will improve, take a look at the pic and let me know if i did it right. thanks
I have a K&N and never checked on my E-bay knock-off as I don't use the GM MAF yet, but will the K&N filter fit directly onto the Injen/E-bay knock-off intake pipe?
edit: I looked last night and NO, it does not fit.
the hose is not kinked, it just looks that way, i am currently not using the GM MAF so i have to recirculate my BOV.
Jingx284 said:
because i have stock fuel system and turbo, if i knew how to use the GM MAF anf MAFT along with my S-AFC with my stock turbo then i would use it, I am new and just getting into the tuning aspects of DSMs, i looked and checked around about the easiest way to tune my vehicle and could not find anything. and also how do i read my datalogger and what do i do with the info that also confuses me,
