Anyway to tighten the moonroof?
MattZ31
32
Dec 4, 2002
Chattanooga, Tennessee
I've had the balance shaft removed on my 91 and I've noticed that recently the moonroof starts to buzz a little whether it's open or closed. If I put my hand and pressure on it, it stops. Are there any screws I need to look for being loose that I can tighten or is this just common among cars with the B/S removed?
move the cover all the way back and you'll see 4 star screws. Screw those in tight, they probably rattled loose.
edit - just saw you're a 1g, not sure if it's the same
