roll hard 95
- 47
- Apr 17, 2002
to whom ever has removed a dash and painted it or knows anything about this i have a quuestion. Im doing mine tommorrow and i want to know if i should use primer, because if i do i have to get flexible primer because if i dont it wont work on vinyl(i know because i used normal primer on the soft part of my doors and then coated it with vinyl paint and flexible clearcoat, and it dosent stay) But i cant find flexible primer anywhere, and the Plasti-Kote vinyl paint says its sticks to original surfaces. So will i be ok if i just clean it really well, paint it and flexible clearcoat it? Or Do i deffinitly need to use Primer?
Lemme know asap guys cause i have to do it tommorrow, its the only time ive had off in a long time, its going to be warm out, and ima be swamped the next 3 weeks.
Thanks
Thanks
all I can say is man you got style bro
don't do it..it looks fuc*ing tacky and ghey...let me guess you want a 5 inch tach to with a shift light..
, and the heel toe thing is the only reason i have them.
