How do I choose which front clip to use?
JLeach50
35
Jul 25, 2005
Laramie, Wyoming
So I'm planning on getting the Qwuhee's wide-body kit soon and doing some fabrications to it for my eclipse, including using an aftermarket front clip with it. But there's at least 3 different clips that I'm considering to use with it. Your personal opinions aside for now, anyone have an idea how I can go about deciding which front bumper will be best for modification (considering how it looks with the WB kit and how much modification will be needed)? I'm trying to avoid buying one and realizing that it will take too much work or just look like crap after it's too late. As always, thanks for any help.
Your looking at the wrong Wide body. I was looking into that Wide body my self I would say save your self. That body kit has to be completely molded and tell you truthly A girl I no in Cincinnati. She has hated that kit because it is actually starting to sag a little. It was done by a shop. I recomend eather the NX wide body or the GTP. But as far as your answer I would think any kit with a flat side to it should work. you might beable to get away with a bomex or a blits
The kit is made to be molded to the stock 2g front bumper. If would require a lot more work and modification if you choose to go with a different front bumper.
