New system, HOLY POO!
fr33b1rth
280
3
Jan 20, 2003
Kalamazoo, Michigan
Well, in the past i've had a few systems:
1. 2x MTX Roadthunder 15" in a ported box w/ tweeters (powered by an old thump amp)
2. The above system plus 2x Lightning audio 12" woofers (the bright yellow ones) in a Q-Logic 1cu ft. box powered by the ol' JBL BP150.1
3. Audiobahn ABP10T bandpass box w/ 2x 10" woofers powered by a Pyramid PDB2400D amp
4. 2x Audiobahn AW1006T's powered by the same amp in 3cu ft. ported box tuned to 39Hz
5. 2x profile baja 10" subs in a homebrew MDF box powered by the same JBL BP150.1
6. My new system is 2x JL Audio 10w0's in a box made to the JL audio sealed specs powered by the JBL BP150.1 and it SLAMS
That JBL amp has been bench tested at 236W x1 RMS at 2ohms @12.4V and 302w RMS @ 14.4V
Man, these 2 JL audio subs rival the AW1006T's that i had, and that amp was bench tested at 1756w RMS at 14.4V. All i have to say is these JL Audio's are decently clean when you want them to be, and SLAM when you want them too also! Get JL........
Got the JL's for $140 at a local pawn shop from a friend for the subs, and the box. they are like new, and so is the box. I hope to get some pics tomorrow too.
God, i can't imagine the 13W7! I WANT 4 OF EM!
I miss my 00 Jeep Cherokee.
I had 4 JL Audio 15" W4s in a sealed box. It was a nice wall facing out the back. The box was specifically built for the subs and was divided internally to create two chambers. 2 subs per chamber.
I had a Rockford 1100a2 in 2ohm stereo configuration running the subs.....with an optima yellow top and a 1.5 farad cap backing it up.
It was tight and it hit really really hard. They went amazing low too. I actually put 5 cracks complete through the tailgate(fiberglass).
Damn, I miss that jeep.
I still have the subs and box sitting in my garage. And I have the amp in the Eclipse. .....I guess all I need is another Cherokee and I can it it all back together.
i got 2 solox 18's
bein pushed by 16 kicker sx1250.1
8 amps to each sub
a man yall should here this
ive been threw 3 hatch windows and 2 winsheilds
of course i have no back seats
pitbull419 said:
i got 2 solox 18's
8 amps to each sub
how in the hell did you fit two x18s in a hatch they require way too much airspace. not saying that i dodnt believe you i just dont see all of that equipment fitting
Get a JL 12w6 and then life becomes even better! :D I love mine.
But hopefully I'll be getting rid of it soon, so I have newer stuff on my car this year. I want a JL 12w6v2. OMG
It's called a wall. :p
and 3 or 4 custom alternators......., plus battery space, plus amp space, uhm, hard to believe you wouldn't be able to have a front seat either...
I would reely like to see pics of your install cookmaster30 becaus ei have 2 12's L7's and i could not fit a ported box in my trunk without removing the seat, i bet that thing would pound, how many db's have you hit?
DiabloRT said:
Naa....not even with a prybar.
my friend had 4- 15" subs in the back of his 92 eclipse, with 4 of the RF800 amps (1 to each sub). talk about LOUD
fr33b1rth: congrats on your new system, glad your enjoying it!
LOL I've seen it done.. had 2 mean green alternators: one in the stock location and another one where the a/c compressor went... yellow tops were inside the box. 2 9515's with 4 a7hc's burped a 168 on a termlab. :thumb:
