Drewcool2
- 234
- Jun 15, 2003
Downingtown,
Pennsylvania
I was playing around with my headunit and accidentally shorted it out.
I'm taking power off of the factory headunit wiring harness. There is a +12V (switched via ignition), and a normal +12V lead. It is the normal 12V lead that has no power. This is power for both the radio and the overhead lights.
I can't seem to find any bad fuses anywhere, and I was wondering if there was a fusable link on this wire. Which fuse is it, and is there a fusable link as well? If there is where is it?
Thanks for any help!
I'm taking power off of the factory headunit wiring harness. There is a +12V (switched via ignition), and a normal +12V lead. It is the normal 12V lead that has no power. This is power for both the radio and the overhead lights. I can't seem to find any bad fuses anywhere, and I was wondering if there was a fusable link on this wire. Which fuse is it, and is there a fusable link as well? If there is where is it?
