need help instaling my new gauges
Killa95GS-X
126
Oct 29, 2003
sacramento, California
well i finally got my triple pillar and my oil pres and boost gauge still waiting for a/f ratio but i was wondering were everyone hooked up there oil pres. gauge it is a mechanical autometer i hooked my boost up to one of the vacuum lines right next to the master cylinder and shoud i hook my oil pres up to one of the little ports onthe left front of engine or is there anywere else closre to the drivers side i can use? thanks for the help.
nick :thumb:
1993eclipseGS said:
You can also use the bolt on the head,(Left front) But the readings will be less accurate.
Its been a while sense ive seen a 2g head, somone correct me if im wrong, but ther is no bolt there on a 2g.
the 2G heads have the same hole as the 1G heads except it isnt used for the turbo oil feed it is plugged from the factory. The T25 gets the oil feed from the oil filter, so i don't know if you could use the filter for getting readings from if you are still on that turbo (i don't have an aftermarket oil pressure guage so im not sure if the filter is useable). I would probably use the head until you upgrade turbochargers.
thanks for all the help guys i appreciate it i am going to use the bolt on the head.
nick :thumb:
