How to install shift light?
90GSXDan
224
Aug 8, 2004
Long Island, New York
I was wondering if anyone knows how to install a shift light on a 1990 eclipse gsx. I cant find where to connect the green wire. Thanks in advance for all the help.
I bieleve there is a power12v, a ground and i connected the 3rd one to the speed sensor wire on the ecu( just splice into it). i believe it is # 18 on the ecu pinout chart.
Thank you for your help ill try that tomorrow and let you know how it worked out.
Where is the ecu located, and/or is their an easier place to find this wire then right by the ecu. Also is the ecu labeled with the # wires. Thanks again for the help.
    • eclipsemf
