Problem with headlights
aaronm_2003
248
Aug 14, 2004
Vincennes, Indiana
I just bought some new bulbs for my headlights to replace the stock ones. The only problem is that I can't take the old ones out. :cry: Do I have to take the whole headlight housing out? And if so, how do I go about doin that?
:confused: twist and pull dude.. and if not, wiggle that SOB out.. it SHOULD come out. just look around, i'm sure common sense will tell you if you need to do something to get those out.
also, there's a clip holding the bulb [on the harness] in if that's what your confused about
there is a clip on the back...wait...before that twist the outer plastic piece off :laugh: ...then holding the bulb is a clip. push the clip down and up/down and away and the headlight bulb should come out. when you put the bulb back in make sure you line it up. :thumb:
Yea, I got it finally. I was trying to just take out the whole damn thing instead of takin the east way out. I guess maybe I should pay attention to the obvious. :thumb:
