91 front replacement
91 talon 2.0
Aug 28, 2002
can i use 92 to 94 fenders, hood, bumper ect... on my 91 talon????
also my roof is dented like someone did a clog dance on it what is the best way to fix this????
Yes, you will need to 92-94 headlights, side markers, hood, fenders, bumper, radiator support, all the splash plastics underneath, and some other odds and ends. IMO keep the 91 front end with the pop ups, it looks better.
I've looked for body kits for the 90-91 1gs, and none of them really change the look of the car all that much unless you have the bass body like I do. The best kits I've found so far is the Drift kit, BMX FB. It can be found at www.extremedimensions.com. Even the Xenon kit is really weak. I think there should be some better ones made, but until then I'm gunna leave my car stock.
i really dig the flip ups but i cant get them to work on my car plus most of the front end peices need to be replaced so i was just curious about the swap, idunno i'll make my mind up at some point
Just run to the junk yard and pick up some new motors for the flip ups, or check Ebay or www.dsmtrader.com The longer you wait and stare at your front end, the more you will like it. I know when I first got mine, all I wanted to do was to change the front end into the 92-94 style. But after I kept looking at it and comparing the two, I decided I would never give up my pop ups for anything.
    • eclipsemf
