F/S: JE Pistons for 6bolt 4G63, 3.5in GM MAF
sharobious
197
Jan 10, 2010
Anchorage, Alaska
I have forsale a complete set of JE pistons 84mm specific for a 2.3 stroker. Your block and head would need to be machined to .0040 over. Im guessing on the head part. Not too sure never had a motor built. These pistons are used. I bought them intending to use them, but sold my 1g. They had typical carbon build up which I can clean off them if you like. Has fairly new hardware. To complete the 2.3 stroker build you can use these pistons + stock 6 bolt rods + 4g64 crank + machine work= 2.3 stroker. Im only looking for what I paid $180
Next is the 3.5 GM Maf. Its been half ported. Has the connector you need to splice up to a MAF-T. Im only looking for what I paid for it $40
I'll get pics up in a bit.
Just finished cleaning most of the carbon off the pistons....i'll have pics up after I drop my daughter and girl off...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
