Electric Fuel Pressure Gauge?
Not sure what you mean. You want one with a sending unit to install under the hood, then you run the wires inside the car to the gauge. As for hooking the sending unit up, I would suggest to hook it too the port on the AFPR. I have seen some people "t" into the line and use clamps and barb fittings, but that is not the ideal way to do it IMO.
Jason
electronic FP gauges are about $250.... mechanical are much better but if you wana run it in the car its better to run electrical.
if you have a fuel pressure regulator you can just tap it off that...
keep in mind... you cant just cut the rubber fuel line and put it on there... youd be much better off running a braided SS line from the filter up... and buying the fittings....
its not like connecting hoses onto hose barbs or anything... kind of alot of screwing around.
