View Single Post
Old 01-10-2004, 09:43 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
DSMJim Offline
Proven Member
DSMJim's Avatar
Tech Posts: 2,148
Classifieds Rating: 0
Reputation: DSMJim is a DSMtuners ExpertDSMJim is a DSMtuners ExpertDSMJim is a DSMtuners ExpertDSMJim is a DSMtuners ExpertDSMJim is a DSMtuners ExpertDSMJim is a DSMtuners Expert
Magnus Sheet Metal Intake Manifold Install
Intro
This is a guide to help you with your intake manifold install. It is done on my 98 Talon with a 7bolt however the process will be much the same on a 6bolt, just a slightly different manifold. Also installed is a 1G throttle body and all emissions equipment was deleted.
Before we get to it I would like to give a "thank you" to Sean Greene at HCI magazine for printing this in the magazine early 2004. Also thanks to Marco at Magnus Motorsports for manifold to install and review.
Difficulty: Advanced
Time: 15 Hours (3 five hour sessions for myself, I’m a slow careful worker the first time I do a job)
Reward: Huge!
Beer: One 24 will suffice.
Things you will need:
You will need all your standard tools for this, however a few extras will help like:
Small Welder to adjust your intercooler pipe
Chop saw for cutting your upper intercooler pipe shorter / angles
Grinder to shave things down, clean up edges
Dremel with lots of bits
Smaller battery like on from a Civic (we can now thank Honda for something…)
Preface:
Here is what the manifold looks like. It is said to yield a 40-60hp increase over a stock manifold. I have yet to dyno or really try my car out, however everybody that uses it reports amazing results. I did drive it directly after the install and noticed a large top end increase from 5500rpm onwards and no negative effects below 5500rpm. Transient boost response was completely normal and felt just like my car did with the stock manifold.
Visually the Magnus intake is very nice, Marco said “Make it bling and they will love it” and he was right, it just looks great under the hood. It is a huge improvement cosmetically over the stock intake manifold.
Few things you should know before starting:
The manifold moves your throttle body around quite a bit so you will have to adjust your upper intercooler pipe so that it fits. Generally I noticed the throttle body was closer to the drivers side of the car by 2”and lower by 2”. The stock intake manifold is a bit of a pain to get off so take your time and don’t get frustrated. Once the stock manifold is off all the hard work is done. After that it’s all the fun stuff. I found doing the install in stages really helped me out. Do the hard part first, then walk away and come back for the fun stuff when you mind is clear. This really helped me keep from scratching things I didn’t want to scratch because I was upset.
Ok here we go… IMAGES ARE ABOVE CORROSPONDING TEXT
This is how the engine bay looks before you start anything. Always a good idea to take a before picture so you can admire all your hard work afterwards.
You can start by getting the obvious stuff out of the way like your strut bar and battery. It is a good idea at this point to have a few boxes or cans laying around for you to put bolts into. I have a part tray that has lots of separate little spots in it for different bolts. This was a great way for me to separate bolts from different steps.
Loosen off your bolts holding on your upper intercooler pipe. Your throttle body is held on with two bolts and two studs with nuts on the ends. This helps to align everything before you tighten it down afterwards. Pull the upper intercooler pipe out of the engine bay because you will to have to make some modifications to it before it will fit back in.
Take the throttle cable off the throttle body and lay it to the side we will do more with that shortly.
Unclip all the electrical components (remembering what goes where) from the injectors, coil pack, igniter etc etc.. Everything that is associated with the wiring harness that goes around the intake manifold.
Unbolt your fuel rail and injectors and lay them to the side. My return was long enough I could just lay it over to the side of the car with no problems. Pull you injectors out and keep them some place safe. If your putting on a Magnus intake, chances are you have aftermarket injectors and you don’t want them dropping all over the place.
Remove the coil pack and igniter from intake manifold. We will have to find other spots for these afterwards as they will not bolt down to the Magnus intake anymore. Set these aside as you will need to do some modification to them for re-installation
With everything unplugged you should be able to pull the wiring harness to the side. Don’t forget the knock sensor which is clipped just under the intake manifold. This way you can pull the harness over and move it completely out of your way. Make the next few steps much easier. This process was very simple, so don’t try and work around the harness because you don’t want to move it. It will cause you a lot of headache later on.
Using the double nut procedure you can take the studs out of the manifold. This is using two of the nuts locked together on one stud so you can use them to take the stud out of the manifold. You won’t be able to pull the manifold and throttle body out in one piece. At least I found it much easier to remove the throttle body first. You will want to disconnect all the vacuum lines on the top of your throttle body and the coolant lines on the bottom. Once that is done you can easily slip the throttle body off. Make sure you plug the coolant lines with something to minimize the coolant that spills out. I lost very little in the whole process.
Here is the 1G throttle body (left) vs. the 2G throttle body (right). You can see the obvious benefit of going to a 60mm throttle body from the 52mm found on a 2G.
____________________________
-Jim
Visit DSMJim's homepage!
Advertisement
To browse the forums without the advertisements above, Login/Register
