View Single Post
Old 09-23-2003, 11:05 AM   #2 (permalink)
Wilsonman02
Proven Member
Classifieds Rating: (0)
Reputation: Wilsonman02 is an unknown
Well you didnt say what u were having trouble with, so here it goes....
Find the release cylinder on the left side of the clutch housing, then remove the dust cap which is over the bleeder valve. Put a plastic tube over the valve, place the other end into a container of at least 2 inches of hydrolic fluid, (the hose must be submerged into the fluid). Its best to do with someone else's help, have them press on the clutch pedal, and make sure the bleeder valve is open, and make sure the clutch master cylinder is full, and keep it full as the fluid bleeds out, continue pumping the clutch until ALL air is out of system, and that nothing but hydrolic fluid is coming out, and no air bubbles what so ever, then close the bleeder valve, and put the dust cap back on and the clutch master cylinder cap on as well.
Offline
[posts] Reply With Quote
Sponsored Links
