Quote:
Originally posted by jdmawd
Nice work it was brought to my attention that if you tap the Fuel Pump relay that's a 12V source. The idea of a voltage regulator did cross my mind but I had no idea it would be only 2 bucks. ill check that out at Radio Shack.
I couldn't find a diagram on the Radio Shack site, so I'm not sure how you adjust it. Most like it has two pins on it that you put a resistor between, and the resistance of the resistor sets the voltage. That's my guess anyway. I have only used their fixed 5v regulator ($1.49
), so I don't know what this one looks like exactly.
The back of the package should have a diagram that shows you how to vary the voltage, so you can decide when you look at it if you think you can swing it or not. It's probably pretty simple.
I'm a pretty amateur electronics hobbyist, but I would be happy to try and help you figure it out if you send me a picture or something. But it should be simple.
HTH!
-Adrian
