Woodsy0
- 177
- 2
- Apr 1, 2004
Lexington,
Massachusetts
As stated, I just installed a VR-4 pump. Because of a fuel fitting mishap and an extremely rusted-over car, this was accompanied by a brand new fuel pump assembly. I transferred over the o-ring and the other two pieces that came from the top of the stock pump as per VFAQs instructions, and torqued everything down. I used -6 AN lines as well (I know they're not needed, the fuel line needed repair so I figured it'd be better than buying OEM) and torqued them down to specs. Ran the fuel pump relay to check for leaks both at the pump and at the rail, no leaks whatsoever.
However, on cold starts, the engine idles like crap, and if I'm not careful to blip the throttle at idle or when I disengage the clutch, the car dies. However, the problem totally disappears after ~5 minutes of operation...
Any ideas? I know on the VFAQ, it states that if the o-ring is kinked or torn (I did forget to lubricate the ring prior to installation) that "the car will be hard to start after sitting a few minutes, as the kinked/torn O-ring will allow the fuel to bleed out of the feed lines. The symptom will be that the car will take several seconds to start after sitting more than a minute or 2, but starts right up if you turn it off and then immediately start it back up." However, while this is similar to my problem, it's not totally the case, since the car can sit for 15-30 minutes after the initial heat-up and be fine to restart - it's only on cold starts (after the car has been sitting for several hours) that this happens...
Thanks,
Scott
Thanks,
Scott
p ), so anythings possible...
, before he got enough beer available to accurately troubleshoot this issue...
after all, and they like to be sure that we're paying the proper attention to them...so they just beg for attention in strange 'n unique ways..
