Log Advice Please
cool_g_83
300
Jan 8, 2005
Parker, Colorado
Just got a logger and did a run. How does this log look? I have read that o2's abouve .92 is rich and below is lean (is this right?). If so, would it be possible to turn boost up a little?
Code:
RPM         Timing        O2 1 Bank 1
3180.0      27.0          0.82
3297.0      27.0          0.72
3500.0      8.0           0.96
3723.0      8.0           0.96
3949.0      10.0          0.96
4145.0      11.0          0.96
4359.0      10.0          0.96
4551.0      10.0          0.96
4746.0      12.0          0.96
4961.0      12.0          0.96
5121.0      13.0          0.96
5309.0      15.0          0.96
5492.0      16.0          0.96
5660.0      16.0          0.96
5820.0      18.0          0.96
5973.0      19.0          0.96
6121.0      20.0          0.94
I wouldn't go much over 16psi. After that, the T-2small just starts blowing hot air. Also, before you up the boost, make a pull and log airflow. Then after turning up the boost, log airflow again and make sure that youa re getting a corresponding airflow increase. If you aren't, I would turn the boost back down.
Remember,
Airflow = power
Pressure (psi) = heat
:thumb:
    • eclipsemf
