5 speed 420A transmission
Transmission mount
Shift cables
ECU
Shifter
Master cylinder
Slave cylinder
Clutch fluid reservoir
Clutch Pedal assembly
Brake Pedal assembly
Shift boot
Shift knob
Clutch
Flywheel
Correct me if I'm missing anything. Not a 420A guy but my cousin just bought a complete swap kit from a guy in Miami who has a Mitsubishi graveyard. Everything listed above was what he got for $660. We're getting a new clutch instead of using the used one. I'll be helping my cousin with the swap. I guess if you're doing all the labor yourself it shouldn't cost that much. It also seems as if it would be better to take the engine out and drop everything back in together. We'll also be fixing a few oil leaks around the oil pan and replacing both axles.
____________________________
2GB EvoIII 16G Powered GST
