Quote:
Originally posted by alltalon
well u have answered almost all my ?'s but i have more!
1. is the talon engine the same as a eclipse??
2. is it better to get a turbo harness other that trying to keep the nt one??
3. i have a 2.0L nt talon 6 bolt, do i have to get a 6bolt engine and standard??
4. how is that grinding thingh u said about that you have to grind alittle in order to fit your flywheel??
thanks!
another thing can i just get a turbo 2.0L engine and drop it in my talon??
please help me
Yes,the eclipse engine and the talon engine are the same,both manafactured by mitsubishi.
Installing a turbo wiring harness is quite a job in itself,but it makes the engine install a little easier(not worth it to me).
You don't HAVE to get a turbo 6-bolt,but you'd be alot better off.
On the transmission side of the block where the flywheel bolts on,there is a little bump on the crankshaft and the turbo flywheel is keyed to accomodate this bump, you have to grind it off in order to retain your stock N/T flywheel.
