Wiring Harness Replacement? Which YEAR DO I USE?
Cody Morris
97
Jun 5, 2002
I have a 93' Talon which is being turned into a turbo Talon now. I have a 6-bolt block being used with a stock GST turbo (temp) and need to know for turbo wiring harness replacement, should I get one from 91', or can I get a 1990 Wiring Harness? Also, should I try to match the year of the wiring harness with my ECU? PLEASE HELP, MUST GET PARTS BEFORE SCHOOL STARTS!
If you are using a 91 or newer ecu get a 91 or newer harness. You can make it work with a 90 harness and vice versa, but making less of a headache for yourself is always better.
