1997RS
- 211
- Dec 4, 2002
Little Rock,
Arkansas
I have brought this tdo4 out of a lebaron and was wondering if is any good, power wise for the 420A? any suggestion please thank you.
george
george
I hate to break it to you chief but Hahn ran a 10.87 1/4 mile on a stock head with much boost and some nitrous. I highly doubt they could do that if the head was a weak point. It sounds like you had a problem before you put in your new block. I run 18psi daily on a completly stock head (with over 100k miles on it BTW). Plus with only 256 miles on the rebuilt block you shouldn't have been boosting it at all so that shouldn't even be a factor anyway. Your problem must have already been there or it must have been something you messed up on with the rebuild. But there should be no issues with your valves because of turbo.Originally posted by GS--t sleeper
the 420a can only handle 350 hps on low millage moters stock so if you plan on shooting 15 psi at it. plan on a new motor cause you can kiss you vavles good bye the stock valves are not that good when they have a lot of miles on them. i didnt change mine and i had 256 miles on my rebuilt engine and one went it destroied my brand new je piston and the head. it also left me stranded on the side of the road. so just be carefull when you build your motor or if you leave it stock and justboosst the crap out of it if gets spend on a gs and rs good luck to you
No offense but it makes it twice as hard to read a post and understand what is being said when every word is mutilated. Kirby definately knows what he's talking about when it comes to the 420a, as you might also, but he is just trying to make sure the right information is out there. Funny how tempers always flare here, with stuff like "Listen Chief" or "Are you stupid?", and other sharp-tongued phrases.. It's obvious why our N/T - Turbo Conversion forum has been dead lately.
If only the bottom end was as durable! Just blew my motor and thinking about selling it and buying my friends project 94' Supra. It's missing the turbo system and the wheels but has all the supporting mods already installed to go single turbo. I am very, very tempted needless to say! That car will be the death of me though.
I was sick of always having that worry whenever I was under full bost while using stock internals.. now I won't have to worry anymore! eheh, plus i can crank up that boost when I get the larger injectors! Hope to get in the consistant mid 12's on my street tires
supra
