NT - Turbo - Need some help.
sike
59
Dec 18, 2001
Baltimore, Maryland
Ok, I'm just about finished the install, but there are a few things I need to know before I can finish up. Sadly I only know half of what I'm doing, but I'm almost there.
#1: I have a greddy Type S blow off, theres a hose that screws into the side of it, it looks like a fish tank hose... hooks up where?
#2: The wastegate actuator vacuum hose should hook up to the intake manifold vacuum ports... correct?
#3: SFMU: Vortech SFMU: Where the hell does this thing go?
#4: Boost gauge: Where do I connect this?
Sorry for the stupid questions. My AIM SN is SikeX, I could really use some help! Thanks.
on the very top of the bov you have a hose port. you take the hose connect it to the top of bov and then to the intake manifold.
wrong, the wastegate hooks up to the boost contoller if no boost controller just hook to compresser side of turbo.
your boost gauge hooks up to your intake manifold vacume lines.
the vortech sfmu you are going to need to read the directions or call them we are not sure what exactly one it is.
That would have been bad mkay? I have a pic of my engine after the N/T -> FI conversion with star turbo kit you can see some of the lines and how they run. Might help just for visuals sake. Boost controller used the fuel vacuum line (Sorry I forget the exact name it's been almost 7 months since I've had to remember).
