Stage 2 Wastgate (8psi) What Else do I need
InfamousEclipse
1,928
2
Jan 11, 2003
Tri- Cities (c³), Washington
I got a stage one HRC but an 8psi Wastgate.
1st off, is it a stupid risk to run without a SMIC atleast? Is there anything else I need to run SAFELY? If Stock GST Injectors work w/ me, I can use DCs as an upgrade for mine- is that smart?
Thanks
why do you want to risk it? your kit (turbo) is a big investment.
Go on to ebay, take a look at the nice FMIC done by CCA or similar companies, you can obtain a more then adequate FMIC for under 250.
Like the sig says, boostin on a broke budget. I have access to stock 2G GST SMICs I can use DCs but... its the piping that gets me.
I should make another post on that
