SgtAJ
- Aug 11, 2003
Brandon,
Hey, is EVERYTHING included in the Hahn Stage II kit? Or is somthing else needed? I don't want to miss out on somthing important
Thanks,
A.J.
Thanks,
A.J.
Originally posted by justincredible
The kit comes with all the essentials to turbo charge your car. Of course though, there are some things that you could get to make your car better like gauges...vortech sfmu....bigger fuel injectors....fuel pump ...blah blah and the list goes on
Originally posted by slodsm
That is a huge negative, the kit will come with EVERYTHING you need to do it. You need buy nothing more, at all. An EGT gauge is nice but not required if you are staying at the stock wastegate boost and follow Hahn's tuning instruction to a T. Don't listen to people with NA cars about Turbo installs, how the hell would they know???
Originally posted by soulcontroller
i consider all the items i listed as necessary. if you want things done correctly anyway. but thats just me.
and justin, if that was directed towards me, let me know what you think when you install your turbo kit...
Originally posted by iceman1421
MY KIT DIDN'T COME WIT A BOOST GAUGE. AND AN AIR FUEL GAUGE IS PRETTY WORTHLESS (HAHN TECH GUY TOLD ME HIMSELF) BECAUSE ITS NOT REALLY THAT ACCURATE. OUR O2 SENSORS ARE PRETTY INACCURATE. AS LONG AS YOUR RUNNIN A CERTASIN AMOUNT OF FUEL PRESSURE WIT THE MATCHIN BOOST THATS IN THE MANUAL U'LL BE FINE
but other wise when my car gets to normal operating temp hold on to yourself because i can smoke the tires at 60 mph going down the freeway. it is pure adreniline but strongly recomend using hahns!!!!!!!!! i am very happy i did i just need a fuel management and i can run 30 psi with a new clutch from them because i ate my brand new centerforce stage two there is to much hp in my car. so do what you want but dont go star you cant keep upgrading like hahns. they now have 7 stages!!!!!!! weee haaaOriginally posted by GS--t sleeper
i installed the stage three turbo system fromn hahns it was the best thing i ever did i was thinking about the star kit but i got the hahns kit with everything you need the only thing that is missing in my car is a fuel management system but i run 15 psi on the street and keep right next to a corvette zo6!!!!! but my motor is built. the third stage sends you je pistions, crower rods, ignition from crane with a map sensor and retart switch, profec b boost controller, greddy type s bov, thermal reaserch and development cat back, booster fuel pump, fuel regulator system, a piller gauge pod, autometter, boost gauge, super 16 g turbo, manifold, i also upgraded to the tight looking front mount intercooler, the piping is awsome and a turbo filter. but if you are going to rebuild your motor make sure you change your valves all of them it is important i threw a valve on my new motor with only 256 miles on it!!!!!!!! was not happybut other wise when my car gets to normal operating temp hold on to yourself because i can smoke the tires at 60 mph going down the freeway. it is pure adreniline but strongly recomend using hahns!!!!!!!!! i am very happy i did i just need a fuel management and i can run 30 psi with a new clutch from them because i ate my brand new centerforce stage two there is to much hp in my car. so do what you want but dont go star you cant keep upgrading like hahns. they now have 7 stages!!!!!!! weee haaa
no bad comment here for hahns they are pretty damn good not to bash star that is not what i am trying to do i just hope this helps and happy boosting![]()
i am not treying to bash star but i dont want to see anyone else go throught what i went through with my valves and destroied my brand new pistion. you have to figure the head is at the machine shop anyways getting decked so it is easy for them to put new valves it then in steed of tearing the engin down again but i also have a 5 layer race grind on my valves and you dont so air flows faster. not trying to be adick but i looked into star had one on order and they screwed me and didnt send it to me. so i canceled and called up hahns and was just asking them questions. and he through a list together faxed to me and i liked what i saw it had more options than the star kit to and at hahns you dont have to buy the stages together you can buy individual items. so i am not trying to argue with you i am just letting everyone know what my opinion is. so your car is fast but so is mine. so are we cool?
ps. wondering were you got stage three axles at i need them i have been burning throught the stock. and what is a good fuel management system to run just wondering? i am also sorry if i offended anyone with the dont go star line. it is probably just as good. later
