dual exhausts
97eclipseRS
1,321
2
Jan 14, 2003
Ft. Myers, Florida
i was thinkin about possibly puttin on a dual exhaust setup on my car sometime in tha near future. i will have a stage 3 hrc turbo on (hopefully) when tha exhaust goes on. im just wonderin if it will take away any of tha power from tha turbo kit?:dsm:
Not power but depending how it's done it will cut down the flow of the exhaust. Why put another restriction in the system. Dual exh looks strange on a car without the cutouts for it anyway.
actually if it's piped normally and uses two low restriction mufflers it will have slightly less backpressure in the system than before since you'll be dividing up the exhaust flow between two mufflers. although i don't imagine you'll see any really huge gains with this setup, don't expect to see any losses either. most people run single since its easiest and works just fine.
