siueclipse
- 1,546
- 6
- Sep 11, 2002
ok.. well.. here is what i currently have...
hahn stage 2 + fmic
310cc injectors
this is what im doing right now...
bored motor 20 over
je pistons
eagle rods
limited slip differential
cam gears
under drive crank pulley
2.5" turbo back exhaust
pulley set
motor mounts
this is what i should do in the future...
oversized valves
better valve springs
cams
probably larger injectors
car should be done on friday. i plan to run about 15lbs of boost at first, then after awhile i might turn it up some and see what i can get out of it. i was thinking about running nitrous but im not sure if i want to run that way or not.
any suggestions on what i could do after this point? i know i need better brakes, but im speaking more along the lines of the motor. axles would be nice, but damn those are expensive. (not like i haven't spent enough money anyway).
what would you recommend i run for boost with this setup? how much hp to the wheels do you think im going to see? do you have any thoughts about this setup and where i should be taking it?
thanx
James
hahn stage 2 + fmic
310cc injectors
bored motor 20 over
je pistons
eagle rods
cam gears
pulley set
motor mounts
oversized valves
cams
thanx
James
I did make mention of breaking the internals in first
