mhe
- Feb 27, 2003
Here's my problem: as an european DSM owner (in my country, called austria AFAIK, only about 30 of them rolling around) I'm doomed to have an 4g63 without a stock turbo, so i cannot use a turbo upgrade kit like the HRC or Star ones, which really drives me mad...
The only bolt-on turbos I've found for N/T engines are to be added to 420A engines and that makes them not very usable for me.
My stock engine is exactly an 4G63 2.0 DOHC 16V (since I've never seen any other DSM engines than mine IRL, I do not know if this is something exotic or not)
All I'd like is to get my engine up and running with about 275-300 hp without using nitrous.
Engine swap is no option, because swap engines are almost impossible to get here and JDM engines are sometimes in very bad shape when you get them.
So does anyone know how to make a turbo kit for an N/T 4G63 and could also tell me if I would have to go for a rebuild?
I'd do anything for it except spending vast amounts of money for little or no use
Or asked a simplier: What parts would I have to get in addition to let's say a HRC Stage II Kit so that i could install it into my little engine and blow some of the ugly golfs and jettas off the street?
(And yes, as you can see I'm not very deep into automotive engineering, at least not yet, mind, car and knowledge grow as time goes by, so don't blame me for being that stupid in the beginning, not everyone was born with a wrench in his hands (I for example was born with a computer
I'm not very good at english either, but reading all of your very valuable threads keeps me motivated to push harder in any aspect of the things i mentioned above
greetings from austria
martin
)I'm not very good at english either, but reading all of your very valuable threads keeps me motivated to push harder in any aspect of the things i mentioned above
martin
