lilbayz311
- 101
- 1
- Feb 15, 2005
Ogden,
Utah
ever since i first turboed my car i haven't been able to get rid of this code. i have had both the hahn racecraft fuel cut defender mod that isnt that reliable, and i currently have the missing link installed, which does not allow my map sensor to read pressure, instead it opens it up to the atmosphere through this little air filter. it is a badass little valve but it never got rid of this annoying code. (I also tried at the same time a new map sensor) i have sent my ecu in one time when i couldn't figure out why my car wasn't starting after replacing the pistons and supposably they fixed anything that may have been wrong with my ecu. that turned out to not be the reason it wasnt starting anyways, but my ecu should be good. i can clear the code and start my car soon thereafter, and it will run will no CEL until i shut my car off and start it again it is always back on. i can clear the code and wait 5 minutes to start my car and by that time the CEL will already be on even though i just cleared it 5 mins ago and just barely turned it on. ive been having this problem for over a year now does anybody have any suggestions?
