95 ECU in a 96???
ckiel
Mar 3, 2005
Columbus, Indiana
If this is possibile will it eliminate the need for the ML?? Just a thought! Thanks,
-ckiel-
-ckiel-
yes and no. if the answer is yes, then your ecu wont need a missing link. if the answer is no, you need a missing link... ok basically, if you have an early 96, you have basically the same system as the 95, and wont need a missing link. if you have a later 96, you have a dual harness ecu, and you cannot swap.
