Recirculate?
Turtle
Sep 5, 2004
laramie, Wyoming
With our 2G cars would anyone recomend recirculate or venting? with a greddy type s
wont there be a power loss? oh and my mind is spacing, what is the second nipple on my wastegate and on the greddy BOV for, LOL i can't seem to remember.
I thought u put the boost controler inline with the line from the manifold to the bottom one. i have the 7psi pring installed, are you talking about with no spring involved?
Hope this helps, this turbo shows a acutuator but a external wastegate is basically the same setup
NO that is with the spring in it
if you have an acutuator with one "nipple" then you would put it in line
but since yoou have two your boost controler goes on top to keep perssure on the spring until the desiered boost level is reached then your gate will open
so if u didn't have a controler then you would just put the line on the bottom one? and it would hold it at 7psi correct?
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
