downpipe
joker53773
Sep 3, 2002
hello im going to turbo my car and wanted to know if i had to make a new downpipe or will a aftermarket one work from a turbo car and what about the rest of the exhaust anyhelp will do thanks
I suppose that if you are going turbo by swapping parts from a 4G63 turbo onto your N/T motor, then you will be able to use the same aftermarket downpipes for the turbo engines as long as you are using the same exhuast manifold.
Anyone correct me if I am wrong.
No, you are right, you can use the same one. Just as long as it is big enough. say around 3".
