there is a clickin in my suspension
gookgangsta
Sep 15, 2002
when ever i go over a bump or let go of the gas i can hear a clicking noise. the noise is coming from the left front wheel . i just changed my rotors and brake pad and the clicking is still there . is it in the suspension?, has anyone ever had this problem?... get back..
it would be a cv joint if it clicked constantly when you turned.if not like the guy on top it could be a bad strut,or the base of the strut,it could be your tie rods,upper or lower ball joints, or even the control arm bushings.if its the last one you have two options.go to the dealer and have them rip yuo a new one cuz they wont sell you the bushings only you have to buy the whole arm,or you can buy energy suspensions polyurethane bushings and have those installed on both control arms since the kit for the bushings for your whole car cost the same as one arm from the dealer,but were getting ahead of ourselves.have a mechanic check it and let us know:dsm:
OR - it could be the completely normal click between the CV shaft spline & the half Shaft at the Center bearing joint... Do make sure your Lugs are tight being you just did a Brake job - I like to Anti Seize the threads - Those Pig-Metal Lug Nuts are crap.
