AEM CAI question
beagle9479
Nov 18, 2003
On the intake for my 2g N/T, there is an extra inlet pipe besides the one that connects to the cam cover. In the AEM directions they say "on vehicles equipped with the air injection hose leading from the exhaust to the stock inlet pipe this hose must be reconnected to the AEM cold air inlet pipe", if not use a cap to plug the fitting. I just wanted to be sure, but I don't have this hose correct?
Also, the stock airbox connects to a piece of plastic pipe that runs under the fuse box. I assume this is the pipe that brings in the air. Do I need to take out this part of the stock intake?
Thanks
Keep the bung on the lower portion of the pipe blocked, the bung near the throttle body goes to your valve cover (or you can block that too and put a breather filter on your valve cover, to help keep your intake clean).
did anyone block the tube that connects to the valve cover and use a breathor filter? mine is connected through that balck tube aem supplies but i was wondering about the breathor filter.
