Need Info on conversion......
97dsmbishi
944
Apr 9, 2002
Hey guys, quick question for the wiseones.....
I have the following, what else will I need?
It's a Td04 Turbo kit. This kit is used and is incomplete but in great shape. Td04 Turbo which is in great shape, has no cracks or shaft play. Also included is the 02 housing and bolts, exhaust manifold with bolts, coolant lines, 02 sensor, banjo bolts, copper gaskets, 02 housing gasket, manifold gasket and intercooler. This turbo is oil and water cooled and can run around 15psi I think.
See attached:
:thumb:
phil
Well you will need to build a down pipe and a fuel system (including an FMU). You will also need to build the oiling system. The O2 is usless because you already have one. Does it have an internal wastegate? If not you will need a wastegate of some type. You'll also need a missing link or some type of Fuel cut defence device to keep the car from seeing boost at the map sensor. There will be other things as well.
this guy is smart just like me..... he actually prob spent around 1000 bucks... im doin the same thing too man....
