timing belt
Talon5786
78
Jul 30, 2003
abingdon, Maryland
Hey everyone i need help is there any signs that you hear before your timing belt i have 73k on the factory belt
You should change your belt immediately. If your belt goes, you could have piston smashing valves and that = no good.
Mitsu suggest replacing at 60K. I suggest you do it now sir.
Oh and have fun too. :)
just got mine done at a local Satan for $300 out the door. They did excellent work. You may here a ticking noise as the rivets in the belt become worn down. As dr1665 said, don't LOLly gag about changing the belt because you could drop the engine just driving normally on the freeway. Make sure you have your water pump and tensioners looked at as well.
Good Luck
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
  • For sale 2g 2g front strut shock cup. MR103156. New.
    Mitsubishi Oem # MR103156 front suspension strut cup. New. Message 702-741-6987.
