Big Questions
MrMustang
Aug 7, 2002
Alabama
My friend has a '95 Eclipse RS. He has the 2.0L DOHC (ya know, the neon motor). He was wondering, with engine mods and everything. How much hp is his engine capable of n/a? Any help would be great. And would it be feesable to do this: He is in the Navy and may get stationed in japan. Could a Lancer Evo engine (not sure if III, IV, or V) would bolt up in his car?
Well if he has a unlimted budget like your other buddy with the spoonfed accord, then the posibilities are endless:rolleyes:
Tell your friend to forget about the evo engine. (while you are at it, tell him to get on the forum... are you his daddy?)
Anyway, I plan on going all-motor-madness next summer with my Esi, and have plans to have it at about 200-215 HP with bolt on mods as well as internal. (CIVICS WILL DIE!!!:mad:
After that, it will be a Stage 2 Turbo Kit, probably from Star Performance. With the engine mods I want to do next summer, I am hoping to be able to run 13-15 lbs. of boost and be slightly over 300 HP, maybe even 350ish. (MUSTANGS WILL DIE!!!:mad:
Obviously, this is going to cost some money...but I want to be a little different than the Turbo owners.
I am going with curtis on this one, i am building my motor completely and have bolt ons and i should be running around the same numbers as he projects, perhaps higher like everyone is debating and then once it is completely built all motor as big as you can get, atleast with my compression, then nitrous and turbo. Which by then will create mass hp, as curtis says Everything will die.
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
