O2 senor question
if you're talking about a 1g then your chances are better than a 2g. If you're wondering about a 4g63 o2 fitting in to a 2gnt, then no, the connectors are going to be different.
An o2 sensor generally works the same regardless of application, provided they use the same number of wires (heated/non-heated). It's just going to be a matter of the length of the wires used, the connector differences, and threads of the sensor in to the bung on the exhaust.
Doug
I don't think that's going to be a direct fit. I KNOW the connectors will be different because you're talking about a mitsu o2 going in to a chrysler wiring harness.
does anybody know if the o2 sensors from a neon will fit fit to a 2g n/t eclipse?? satan wants 150 bucks each for the mitsu ones, but i can get the neons for 150 bucks for both from prostreet. somebody tell me for sure, cuz everybody i've talked to doesn't know, thanx...trust
