what would i run
motrhead96esi
Dec 7, 2002
i have a cold air intake and i just bought adjustable cam gears i'm buying a header and getting full exhaust put on what do you think i will run with all that
stock 2gnt's run around mid 16's if I am not mistaken. I assume you are a 5 speed? I would just guess maybe high 15's, just a guess, I'm sure someone can tell you exactly.
well my stock 2gnt runs a 16.2 with just an intake and i just put an exhaust its a 2 and a half straight pipe ran from header back and i beat a honda with an Ls acura motor and beat it and that ran a 15.6 at he track so if u put camgears u probably would run a little bit faster than that
I understand you were just asking just to ask.
BUT the only way to know is to drag your @$$ to
the track and race that bish!!! Cause you might
be at bad elevation bad temps and you might not be
able to drive very well. Or you may be a great driver.
Either way go race it and come back and tell us how it went.
But don't be a ricer and go around telling everyone that you have
a 15 second Eclipse because some people said so Online.
I'm not bashing you just giving some advice.
Good luck:thumb: and don't forget to come post back with a time slip.
This type of thread is not only pointless, but also repetitive. Go to the track if you are really interested in what your car runs because it's just a guessing game otherwise.
he better come back to tell us. my 95 nt ran 16.09 w/ AEM cold-air and a hi-flow cat back exhaust (2 1/4")
Driving Skill plays a huge roll in track performance. You could have all that done, but if you cant launch or shift then you could still run a high 16 or even a 17. With my car stock (minus running no filter in the airbox) I turned 16.34. Some people can drive better, some cant.
  • For sale 1g 90 Oil Cooler
    • kyler021
