I want more hp from my engine!!help me!!
hotrod
Feb 11, 2003
Hi to everyone, I wrote from Italy and I need some expert help (not possible in Italy where they are about 500 Eclipse and all not turbo)
I've start to modified my 97 with blitz bodykit, h r springs, wheels, rims, and lot more but now I want to increase my hp. I've learn yesterday from a guy that live in florida that my engine is the 4g63 it's a 2.0 liter non turbo with about 150 hp..
What can I do to increase hp?? I'd like to put on a turbo kit but is so expensive cause isn't avaible here and the law about this modified..impossible.. I've buy a Tenzo R intake system but I think is for the 2.0 l chrysler motor.. I want ask for modied the (I don't know english word for it..) elettronic controller?? eprom? ecu? Some people told that is possible gaine about 5/ 10 hp from it.. I've also buy nology hotwires..
Ok now I hope that someone can help me and maybe I can understand other thing about my Eclipse..
Thanx very much (I hope that I've put this message in right forum)
Unfortunately my english is not the best and I haven't understand everything in the german dsm forum about my motor..Is not the same of your in the states?? So I've a question: I've buy nology wires + spurk plugs for n/t eclipse, can I put it on my engine or isn't for my 4g63 motor?? I don't want brake something..
If I'm correct you have the 420A engine, which is the chrysler engine!
If that is true then your plugs and wires should be fine as well as the Intake system that you have!
As for more HP in your N/T ... well there isn't much more than Intake, Exhaust, Wires, Plugs, Unless you want to build up your engine ... meaning all new internals ..... pistons, camshaft, cam gears, so on and so on!!!
you can bore your throttle body and intake manifold, get a 50shot of nitrous, underdrive pulley, cam gears, intake, exhaust, and fuel regulator system
Yes..this is the problem, I've knew a guy that live in florida and he has a 97 turbo, he look my engine and he told me that is a 4g63 not the 420a!!
So if I order parts for the 2gen non turbo I buy wrong parts??!!
Why in europe we have different things!!!??Shit.. Is already hard understand about this car, cause we don't have a lot of it..500 in all Italy.. no turbo version, sold from 12/96 to 12/98 with your gs 95 exterior and different motor..
I've my nology wires in the trunk that hold to be in but now I don't know if is correct for my motor!! Maybe when I back home from work I post a pic of my motor..Please help me..
I'd suggest going with the turbo kit. Not one with Hahn or Star, but a custom/factory one. I'm not sure how your engine has 150HP and the US version has 138HP, but essentially, our engines are the same as the 4G63 turbo motor. See if you can't find someone in America to ship you everything you need for the conversion. You can get easily 210HP on just 5psi, if I am correct. Just research a bit.
