Who sells flywheels for us N/T
geovanie
90
Sep 15, 2002
Miami,
I've been going crazy trying to find a flywheel for my '90 non turbo. First I was told Clutch Masters made it then i was told they don't. Can't find the Fidanza or ACT either.... What flywheels do you guys install in your N/T????
I've never heard of a flywheel being resurfaced/lightend.. Can this be done on a 1995 eclipse nonturbo? How much do you think this would cost for a mechanic to do?
You have to take it to a machine shop and I have no idea how much it costs. Just call your local machine shop and ask if they'll do it for you.
if you have a 4g63 you can probably just use one that a would fit a turbo engine, same trannys
no they're not the same.
geovannie you're not going to be able to use a turbo lightened flywheel such as the jun or the fidanza unless you also make the switch to the turbo transmission and clutch assembly as well.
i've looked all over since i myself run a turbo engine mated to an nt flywheel/clutch/tranny combo. so far its still looking like the only way is to take it to a shop and have it machined, or you could give rre a call since i know they do it to the turbo flywheels, shouldn't be much different for them to do it to yours.
i have a n/t 4g63 but my tranny is a turbo tranny... a few different companys make them for turbos like act and stuff but i don't know about a n/t tranny
its www.slowboyracing.com and they sell fidanza flywheels which are only made for the turbo cars, the 2gnt's, and for some ungodly reason the 1.8 liters. but they still don't make anything that will work with the 2.0 nt transmissions.
