MmmDeion
- 61
- Aug 29, 2002
Rhode Island
Ok... Spring is just around the corner and I have PLENTY of money saved up from the winter time, and I cant keep it in my pocket any longer... Ive made a huge list of stuff I plan on getting soon (like within the next month or so), and my goal is to hit about 170hp or so on the dyno... The total comes to about $3000... And dont say buy a turbo, because thats already in the works (so just keep that in mind with whats list below) Do you think it will be enough to hit my goal??
- Jeep TB with Ported Intake Manifold
- AFX 30% Underdrive Pulleys
- 420a crankscraper (i figured what the hell)
- Howell Automotive Bottom End Kit
Clevite 77 Rod Bearing
Clevite 77 Main Bearing
JE Piston Rings
Mopar Oil Pan
Gasket Set
Melling Oil Pump
Eagle Forged Rods
JE Pistons (8.6:1)
- Fidanza Engineering Camgears (2)
- HKS Cams (264/272)
- Apexi S-AFC2
Thats the list that I have so far... Comment however youd like, because Im still open to any suggestions, like if I might be missing something... I already put a post like this up on 2gnt and have changed the list from the suggestions there... Thanks guys, appreciate it...
JE Piston Rings
Mopar Oil Pan
Gasket Set
Melling Oil Pump
Eagle Forged Rods
JE Pistons (8.6:1)
- Apexi S-AFC2
